Originally Posted by zuzu_
You'd be selling off two of your Kappas then. (But if one is damaged because of the faulty install... sunk cost / lesson learned, I guess.)
I haven't found the third seatbelt to be a problem; it slips out like the other two.
I think the hardest part about if you go forward with the big project of installing a 10" subwoofer in the center of the deck (or slightly off-center because of the third belt) are those two (torsion?) bars underneath in the trunk. They barely leave clearance for 6.5" speakers with any decent sized magnet to begin with. I'm not sure if those bars can be removed or what that would affect with the operation of the car. The third brake light precludes the possibility of positioning the speaker further back towards the rear window.
Well, if the speakers are damaged because of faulty install, I'd be going back to Future Shop to have them replace them, as it was their fault. I would at least exhaust that option before leaving those speakers out of the equation. I won't know until I examine it some more. Swapping with the front speakers makes sense for testing, trouble-shooting.
If I wanted to use those speakers you linked to, I could use a crossover and tweeter, but, I like the sound of the infinity speakers I have. I also like their effeciency. I figure as long as they aren't blown, perhaps an amp would do them better. Either using these 75 watt speakers, or a set of the Infinity component speakers with 95 watts power handling, I could get an amp like the Alpine MRP-F600 with 100 watts x 4 RMS < 1% THD and maybe that will bring me the bass I need. As long as I don't pump up the bass too much, 100 watts into a 75 watt speaker can work. At least if volume and bass boost is kept low, you have enough power to avoid clipping the amp, and that is something that blows a speaker more than too much power. Most speakers can handle more than their rated power as long as it's clean and un-distorted.
The third seat-belt is physically in the way on the rear deck. I'd have to remove/eliminate it. I don't want to do that. I could install a single 8 inch subwoofer with an amp, but, would it provide more bass than two 6.5" woofers if I had 100 watts to each of those? How would that compare ...or could I run 100 watts to each rear speakers AND run an amplified 8" subwoofer on the rear deck? How would they work together? Low frequencies don't always play well together when from different sources/drivers. Lot's of different ways to go. I guess I need to figure out what the system needs most and go from there.
I have a feeling that if I used as big a subwoofer I could put in the rear deck with a nice strong clean amp, I'd probably have a good chance of getting the sound I want. I could experiment with using the HP filter @ 50 or 63 hz in the head unit and/or get a smaller amp and run all the other speakers full range, using the amp to simply make sure I didn't run the deck into clipping. I guess I'd need to try it and test, and then I could tell what it's like each way. I suppose using the 50, 63 or 80 hz HP filter could work as it takes the load off the deck, increasing power available for the mids and highs, and reducing the chance for clipping. As long as the subwoofer blended well and played nice deep bass, perhaps that could be the least expensive option.
It's hard to be happy when you're an 'audiophile' with music. My home system has two tall towers with three 6.5" woofers in each tower and 30 hz -3 dB anechoic response. Into 6 ohms my receiver has no trouble putting out 175 watts RMS into each speaker at <0.05 THD. In room I get close to 20 Hz, although it's not thumping. For that I rely on the Mirage BPS400. Impossible to get this sound in a car without spending similar money. I'm just not willing to drop that much into my car stereo. I don't want bandpass standingwave noise in my car. I want low bass response from music. I want to hear musical notes as low as they can go without spending a fortune. Not an easy task. I am impressed with the midrange and treble in my system so far. If only I can improve the low bass to match, or at least come close :p
Thanks for all the feedback. It's definitely helpful.
