you can put 6x9 speakers in the rear deck. There are another set of openings for 6x9's, but you would need speaker adapter brackets. Plus you would need to cut another pair of holes in the removable fabric top if you want to put 6x9's.
If you put 6x9's in the rear, you only really need just a pair. Having 2 pair is a waste. Most audio aficionados would probably recommend you put components in the front as the rear speakers are mostly rear fill
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
