filling gap for new speakers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2009, 08:21 AM   #1 (permalink)
View rateat's Photo Gallery
I keep reading around the forum that when installing new speakers you should fill the gap between the speakers because it will make it sound so much better. Can somebody explain to me what this means? What do I fill the gap with?
thanks
rateat is offline   Reply With Quote
Old 07-07-2009, 05:44 PM   #2 (permalink)
View gameguru1360's Photo Gallery
they probably mean the backwave between the magnet and the body paneling. You can usually eliminate this with a material called Dynamat Extreme. It absorbs the rattling from the car's body panels
with door speakers, you can use those speaker baffles to protect the speakers from moisture and water, but they actually hinder the sound because it muffles the backwave air.
Usually though with door speakers, you don't really have to worry about backwave air as much as with subs. But using Dynamat Extreme on the door panels and rear deck really helps to eliminate the rattling or unwanted road noise.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
