09 camry rear speaker - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2009, 03:42 AM   #1 (permalink)
View bmw855's Photo Gallery
Gen6 09 camry rear speaker
Hi,
I want to change my 09 camry rear stock speaker (non JBL) here the question? but not sure go with 2 or 3 way speaker since the factory one is very deep cannot eliminate the road noise
1. What is size of rear stock speaker
2. What is the best 3 way speaker to replace
3. Is necessary to install the amplifier in order to get best sound quality when using 3 way speaker
4. If I change front door stock speaker 2 or 3 way speaker will it get louder sound
5. Anyone try to install the speaker in to the lower rear door
Thank!
bmw855 is offline   Reply With Quote
Old 07-20-2009, 04:56 PM   #2 (permalink)
View gameguru1360's Photo Gallery
Originally Posted by bmw855 View Post
Hi,
Thank!
The front and rear stock speaker is 6x9
I would go with 3ways for the front and only 2way for the rear as rear speakers are usually only for fill.
You should install a 4 channel amp if you want better, clearer and louder sound. Another option is to go with a higher rated 2 channel amp to power the front speakers and have an aftermarket head unit power the rears. Then that way you could opt to go component speakers for the front which allow you to place the tweeter wherever you want. Component speakers separate the tweeter from the woofer, are rated much higher than 2way/3way coaxial speakers and also come with crossovers so you can fine tune the components.
Changing the front from 2way to 3way might give you less power if you just stick with an aftermarket head unit because you're changing the way the sound comes out with more tweeters.
To get to the rear speakers in the door, you're going to have to take apart the body paneling. You can try buying your car's data master sheets from crutchfield for $10, but they're usually free if you buy the speakers from them or the aftermarket head units from them. They're not always the cheapest, but they have excellent customer support and include the wiring harnesses/speaker adapters for free.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 01-18-2010, 02:55 PM   #3 (permalink)
View camry66's Photo Gallery
I have '10 Camry and talked to crutchfield the other day. They said that nothing they had fit in the rear deck speaker wise.
What have you all done for speakers back there?
Thanks!
camry66 is offline   Reply With Quote
Old 02-05-2010, 07:33 PM   #4 (permalink)
Really nothing? Nobody has put speakers in the rear deck? Any help would be great.
Old 02-07-2010, 08:44 AM   #5 (permalink)
snake212's Avatar
View snake212's Photo Gallery
i did. i put infiniti 9623i in the front and back. but to perfect it im going to cut out some mdf.
snake212 is offline   Reply With Quote
The Following User Says Thank You to snake212 For This Useful Post:
camry66 (02-07-2010)
Old 02-07-2010, 10:57 AM   #6 (permalink)
^ thanks a bunch! I'm glad to hear that something was done. I'm trying to figure out what kind of speakers I can fit back there. In the '10 there is the trunck hinge that comes right under the speaker so I'm worried about depth.
Old 02-07-2010, 11:50 AM   #7 (permalink)
snake212's Avatar
my speakers are 3" in depth and the trunk bar that moves barely rubs on it, not even enough to make a mark on the speaker magnet. now i installed these speakers with no bracket or anything just a straight up drop in. if you make a half inch mdf bracket it will perfect it.
Old 02-07-2010, 12:10 PM   #8 (permalink)
View Shelbrain's Photo Gallery
If you are going for a sound quality install, just remove the rear speakers altogether and get a good component set for the front. If you are technically inclined, you can buy raw drivers and go active. I am partway through my install now and I found that I actually prefer the sound without the rear speakers installed. Good luck!
Shelbrain is offline   Reply With Quote
