2009 Rav4 MP3 Folders, How to??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2009, 03:51 PM   #1 (permalink)
Rav4 in Show Low, AZ
View ShowLowRav4's Photo Gallery
Okay here’s the problem,.
I have a 2009 RAV4 with the Nav system. I have burned an MP3 CD using I-Tunes and it works okay. Seeing that there was a button for FOLDERS I decided to burn a CD with multiple folders, with multiple MP3 files under each folder. I used Windows drag and drop.
Inserting this CD into the unit I received a “No Music” message. I read the manual and it does not say what the folder structure should look like or if the CD is Music or Data. I burned a bunch of different format and structured CDs and still “No Music”. I called Toyota and got “we’ll call you back”.
So how do I burn a CD with multiple folders of MP3 files and what is the folder structure? Can I use drag and drop?
Thanks
ShowLowRav4 is offline   Reply With Quote
Old 07-14-2009, 01:02 PM   #2 (permalink)
I have it. I just used Roxio and it wrote the CD with the folders. I then tested it and I can choose the folder (CD image) to Play. It will continue to play the next folder if I let it. Also it can shuffle all the folders or just the current folder.
Old 07-14-2009, 08:18 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Did you close the disc? Some drives won't read the disc unless you close it.
2007 Camry 2.4L 5M
Old 07-15-2009, 11:56 AM   #4 (permalink)
Thanks for the pointer. Yes I did close it out. Apperantly it was not in the proper format. I looked at the CD that Roxio created and it had some extra files in the root folder. I have no idea what they do, but I can tell you the CD worked.
Thanks again
