Adding oem Gen 6 nav unit to non-jbl camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2009, 04:15 PM   #1 (permalink)
View nelsonrx's Photo Gallery
Anyone ever tried adding an OEM nav unit to a non-jbl camry? People keep saying its really hard to do, but I have a feeling it isn't as bad as people say. I'm thinking you'd need a way to run a harness from the nav HU pre-out to the amp, and then a harness to run the amps output back to the normal speaker harness that goes in the non-jbl headunit. I've heard from oemvalue.com that theres a guy who sells a plug n' play harness just for this situation so it must be possible. Any ideas?
nelsonrx is offline   Reply With Quote
Old 09-19-2009, 01:35 PM   #2 (permalink)
View rob231's Photo Gallery
Do you ever find the answer to your question? If so please let me know.
rob231 is offline   Reply With Quote
Old 09-19-2009, 02:11 PM   #3 (permalink)
View adschase's Photo Gallery
Is the harness missing? Being OEM it should be plug-n-play. Non-JBL should be no problem, but you mentioned amps, and I am wondering what amps you reference to? Installation is pretty simple and straightforward, but you need the harnesses from the unit to match up with the harnesses from the dash.
adschase is offline   Reply With Quote
Old 09-21-2009, 09:40 PM   #4 (permalink)
View ramkan's Photo Gallery
any luck with this. I have a 2007 camry LE with no JBL. i want to install OEM nav unit. Where can we find the harness that connects the dash to nav unit?
ramkan is offline   Reply With Quote
Old 09-22-2009, 02:49 PM   #5 (permalink)
The harness' should come with the unit!? If not check with your local dealer parts dept. for the price of the harness alone for the OEM NAV unit, or take a look at the Rosen unit for the 2007- present Camry. Complete plug n play and looks exactly like a factory unit, but more funtional. Contact adschase@q.com if you want one.
