jbl amp differences - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2009, 08:11 AM   #1 (permalink)
View nelsonrx's Photo Gallery
jbl amp differences
Does anyone know if there are any fundamental differences between the different jbl amps for all 2009 toyotas? In other words, can you swap an amp for a prius with one from a Camry? It looks like the part numbers are different (862800w390 vs. 862800w460) but the plugs look identical.....any thoughts?
nelsonrx is offline   Reply With Quote
Old 07-24-2009, 11:07 AM   #2 (permalink)
View gameguru1360's Photo Gallery
I'm sure you can and you can probably use different sized speaker terminals to make them fit. The only thing is the different power ratings for each one but if that doesn't bother you, than I'm sure you can swap them out.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 07-24-2009, 04:11 PM   #3 (permalink)
thanks I thought that might be the case. I wonder if they make spec sheets for each of the amps?
