can a Mono-amp be made to run 2 subs?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2009, 09:29 AM   #1 (permalink)
View TNfarmerTRD's Photo Gallery
i can get awsome deal on a 750 watt kicker mono amp, but can it be bridged to run 2 subs??? cause im possibly goin to run 2 10"s.... thanks
TNfarmerTRD is offline   Reply With Quote
Old 07-29-2009, 09:40 AM   #2 (permalink)
^the guitar, not the fish
bassman444's Avatar
View bassman444's Photo Gallery
Yes, if you wire it right.
http://www.termpro.com/articles/spkrz.html
'06, PreRunner, V6, SR5, TRD Sport, Access Cab
It's better to remain silent and thought a fool than to speak up and remove all doubt.
Tom Jackson - Birmingham, AL
bassman444 is offline   Reply With Quote
Old 07-29-2009, 09:41 AM   #3 (permalink)
Native Oregonian
briangp's Avatar
View briangp's Photo Gallery
very easily. mono just means it only puts out one channel of sound, it should still have two seperate outputs for each speaker.
That propellor on the front of planes is really just a big fan for the pilot. Don't believe me? Make it stop, watch him sweat!
briangp is offline   Reply With Quote
Old 07-29-2009, 12:58 PM   #4 (permalink)
lover of teh boobies
johnecon2001's Avatar
Gameroom cash: $462130
View johnecon2001's Photo Gallery
Not necessarily.
johnecon2001 is offline   Reply With Quote
Old 07-29-2009, 01:31 PM   #5 (permalink)
digijohnson's Avatar
View digijohnson's Photo Gallery
You also need to make sure your resistance rating on your subs are within the spec of your amps. Here's a snip from a audio forum explaining ohm's law as it pertains to car audio.
Working daily selling subwoofers and amplifiers at an electronics store, I find myself using these equations several times throuought the day. They are used to calculate the Ohm load, or resistance, when using different wiring patterns for speakers, whether they be series, or parallel
Some amplifiers are 4 ohm stable, meaning they can handle a resistance load of 4 ohms. Other amplifiers are 2 ohm stable. Class D amplifiers are 1 ohm stable.
This equation is used when wiring 2 subwoofers in series.
When R is Resistance, then:
R1 + R2 = Total Load
For example: 4 ohms + 4 ohms = 8 ohm total load.
When wiring speakers in parallel, use this equation.
(R1 x R2) / (R1 + R2) = Total Load
For example: (4 ohms x 4 ohms) / (4 ohms + 4 ohms) = 2 ohm total load.
Using this equation will help you to select the right subwoofers to connect to your amplifier, so that you can get the optimal sound. Most subs are made in both 4 and 8 ohms, so if you can't find the ones you need, ask your retailer.
Hammer Down Son.
digijohnson is offline   Reply With Quote
Old 07-30-2009, 01:26 PM   #6 (permalink)
View dr_green's Photo Gallery
you can add much subwoofers to the mono amp, but it just has to be configured right. the subs total impeadance has to equal the amps lowest impeadance to get max power. right now i'm running a mono kenwood sub amp with two 12's wired at 2ohms. so it depends how you configure your subs and what your amp is rated at. the manufacturer instruction manual will explain how to hook up multiple subs, if you don't know how to.
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
Old 07-31-2009, 11:22 AM   #7 (permalink)
View gameguru1360's Photo Gallery
parallel wiring will get you more power whereas series wiring increases the impedance which basically halves the power so to speak
4ohm dvc subs:
2ohm dvc subs:
4ohm svc subs:
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 07-31-2009, 01:02 PM   #8 (permalink)
4ohm dvc subs:
2ohm dvc subs:
4ohm svc subs:
But you got to remember not in all cases paralleling speakers will not provide you the most power, and that's a fact. it depends on the amps impeadance rating. because if you had dual 2 ohm sub with a mono amp that can handle 2 ohms at the lowest. If you parallel it then your going to break your amp. I guarantee it, unless your amp is really underated. Don't confuse the unexperience by making quotes and assumptions! Sorry not to come down on you hard, but lately no body has been giving good advice, so I'm trying to do my part.
Old 07-31-2009, 03:48 PM   #9 (permalink)
actually that's true. I had forgotten to mention that. I almost damaged my subs that way...forgot that the 2 channel amp when bridged only supported 4ohm but I had wired 2 4ohm svc subs and hooked them up. They were loud, but luckily I had only powered them at medium to loud volumes for about 10 minutes. If I had blasted them any longer, probably that amp would've burned out as well...not to mention the fuse at the amp and maybe at the battery!
The OP will have to put 2 pairs of positive and negative into the leads of that amp. Most mono class d amps nowadays have 2 pairs of positive/negative which makes it easier if you're going to do a dual sub setup.
