queastion regardin car amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2009, 11:44 PM   #1 (permalink)
El_delincuente's Avatar
View El_delincuente's Photo Gallery
ok so i have a 96 toyota avalon. i upgraded the four speakers and the subwoofer....Im new to this car audio thing, i have no knoledge lol. BUT, my queastion is what kind of amp should i use to power them up. The 4 door speakers have 35 watts RMS and 70 watts peak each and the subwoofer has 200 RMS and 400 watts peak. how many watss should the amp should have? my budget $200. Thanks alot
El_delincuente is offline   Reply With Quote
Old 08-07-2009, 01:09 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
Ideally the amps ratings should be as close to the speaker ratings as possible, but an amp with slightly higher ratings should be fine so long as you know not to crank it up past what the speakers can handle. It's always better to have more power than you need than not enough. Not having enough power will cause clipping, which isn't good for the speakers or amp.
Given those power ratings there should be a lot of amps in your price range. There are even some 5 channel amps designed to power 4 speakers and a smaller sub like the one you have.
I have had great experiences with Infinity amps, but they might be a bit out of your price range unless you don't mind shopping on eBay. TheInfinity 5350a is a 5 channel amp that should treat you well. There are a ton of other good amps out there too, and I'm sure others will share advice about what they like, and those will likely be more within your budget.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 08-07-2009, 01:14 PM   #3 (permalink)
View dr_green's Photo Gallery
match the rms wattage or more. that plays your speakers at their best. But it's not necessary to have all the power to make a system run. you can always under power your speakers, and your system will play. your question is so vague, so I can only give you a vague answer. good luck!
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
Old 08-07-2009, 01:56 PM   #4 (permalink)
Hmm...Yeah you right gideon. Ima check ebay lol , I haven't shop there before, but i'll give it a try and see what can i find ...Thanks alot men...Really helped me out with this.
Old 08-07-2009, 02:01 PM   #5 (permalink)
It's where I get all my car audio stuff...it is way cheaper for amps/speakers than even an online store. Just make SURE it's not used...there's no telling what anyone did to it previously...
Old 08-19-2009, 05:55 PM   #6 (permalink)
View gameguru1360's Photo Gallery
well for ease of use, you can look into getting a 5 channel amp...4 channels will power your speakers and the 5th channel will power your sub but usually the power to the sub isn't that much...like 200-300 rms watts. You can go with a dual amp setup, but usually that puts a big load on your battery which would make you either upgrade the battery to a high capacity such as an Optima Yellow top or Kinetik HC battery or upgrading the alternator.
Like what was posted before, you can just get a mono amp to power a sub and get a high rated head unit to power the speakers...I have a kenwood excelon x493 powering my speakers and a lanzar opti 1400d mono amp powering my Sound Stream T5 sub in a 3 cu.ft. vented box. I wanted to have another amp powering my speakers, but that would mean a bigger alt and my 7th generation rolla only has a 70a alt...too expensive to go and get a 120a or 150a alt..
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 08-24-2009, 10:37 PM   #7 (permalink)
Yep, you right about that...I already bought all the equipment. 5 channel amp, 4 speakers. new sub, all i need is a new aftermarket deck ... and then im ready to go lol....But thanks alot guys for all the answers, i really appreciate it.
Old 08-27-2009, 04:11 PM   #8 (permalink)
I'd also get a good quality 4ga amp installation kit.
