I like to run mines as shorts as possible. A little slack is fine, but if you find your self rolling up your rca cable some where in your car, that means buy a shorter one. No sense of adding more noise to your signal then needed. I've seen this done a lot because people don't want to spend more money. So in your case with a little slack your golden!
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
