your factory radio is probably gone. Time to change it out with an aftermarket head unit. I would advise to change out the factory speakers as well as they can only handle about 1-10 rms watts of power. Most aftermarket can handle anywhere from 2-200 rms watts. Never look at peak. peak is just the most it can handle during a brief burst of music. RMS is what you want to look for and that's the continuous amount of power given to it.
2way coaxial speakers are probably best for you to get. 3way is good although with 2way coaxials, you'll get much better sound. If you really want really good highs, then go with components which feature a separate woofer and midrange with separate tweeters you can mount anywhere, plus they come with crossovers so that you can finely tune the frequencies.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
