amp wire location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2009, 04:37 PM   #1 (permalink)
View Marcluv's Photo Gallery
4th Generation amp wire location
how do i run power wire thru the brake booster
Marcluv is offline   Reply With Quote
Old 09-15-2009, 05:20 PM   #2 (permalink)
Bigtuna's Avatar
View Bigtuna's Photo Gallery
I don't have a GEN 4 but based on every car I've worked on you shouldn't need to. On the passenger side there should be a grommet that passes all the electrical stuff to the cabin. Much easier to go through there.
2010 Toyota Camry SE
1992 Toyota Camry LE
1989 Toyota Pickup, 2WD, 22RE
Bigtuna is offline   Reply With Quote
Old 09-15-2009, 09:52 PM   #3 (permalink)
thanks ill give it a try tomorrow
Old 09-17-2009, 12:15 PM   #4 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation
uhh why would you want to?
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 09-17-2009, 06:33 PM   #5 (permalink)
I thought thats where people run there amp wire
Old 09-18-2009, 05:34 AM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Pull the front driver side wheel off and remove the plastic liner. You'll see a rubber grommet with a bundle of wires going through the firewall and then going up through the wheel well into the engine bay.
2007 Camry 2.4L 5M
