suggestions on a new set of components... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2004, 11:22 AM   #1 (permalink)
View xxpanipuri's Photo Gallery
i have a 2000 camry le v6 with the alpine 7894 head unit installed
with factory components and boston acoustic 6x9's and a 500 watt phoenix gold amp pushing a jl audio w7 12" sub.
I want to replace my factory components BUT I don't want to...add an external 4 channel amp for my mids and highs....because i'd have no place to mount it where it'd be out of the way...right now my phoenix gold amp is mounted under my passenger seat....so if i get a 4 channel amp i'd have to mount it in the trunk (on the backside of the rear seats) and i don't want to have to do that....
and also i have this headunit which has a pretty damn clean amp built into it and its 30w x 4 rms...(so they say) its actually quite loud without an amp...
anyways anyone have a suggestion on components to replace the factory ones with...
or if anyone has a similar headunit to mine what components have worked best for you....
thanks!
xxpanipuri is offline   Reply With Quote
Old 02-20-2004, 03:26 PM   #2 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
The alpine 7894 does have a lot of power for a head unit. You should probably go with the matching boston components. Or if you go with another brand, you'd probably want something with a high sensitivity since you only have 27w rms. Focal components have high sensitivity and sound really good too. Check the mounting depth first though.
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
