stumped - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2009, 01:30 PM   #1 (permalink)
View dunkhi's Photo Gallery
stumped
sony xplod hu
audophonic amp powering 4 jbl speakers
pioneer amp powering 13tw5 jl sub
its hard to explain what happened last night but my front speakers started randomly clipping and went out. i went back tried to mess with the amp and the speakers sounded like they were just quite and didnt have much high's. i dont think they blew out because this morning i turned it on and i have good sound coming from my left speaker/tweeter and not my right? im not really sure whats going on but when i turn it up it cuts out for a few seconds. anyone have any clue?
dunkhi is offline   Reply With Quote
Old 11-29-2009, 11:41 PM   #2 (permalink)
Biggg72's Avatar
View Biggg72's Photo Gallery
to much power going into then? wires may be crossed? wires may not be connected all the way? my bet would be to much power going into the speakers. you may have messed up the speakers, but hopefully not.
Biggg72 is offline   Reply With Quote
Old 11-30-2009, 11:34 AM   #3 (permalink)
View dr_green's Photo Gallery
Originally Posted by dunkhi View Post
sony xplod hu
try getting any kind of speaker just to test the amp if it's broken. so just disconnect your wire feed to your speaker and attach a new short wire attached to your test speaker. then you will definitely know if it's your speaker or your amp. make sure you use a speaker that's working. that's how i diagnose those kinds of issues back in the days. i still would do the same today, if i had that problem. knock on wood. so aight man. my guess is your amp is shot. good luck!
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
Old 12-09-2009, 03:47 AM   #4 (permalink)
View murtnabila's Photo Gallery
Could be your amp failed temporarily (might be failing completely soon) and burned your speaker. It happened to me once is why I say this. My speakers started Going in/out to max excursion soon I smelled burnt coil and my speaker fried. Replaced speaker and few months later happened again. Had everything checked out and seems the amp was the culprit.
Good luck
murtnabila is offline   Reply With Quote
Old 12-09-2009, 08:55 AM   #5 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
how are your connections terminated?
check your ground at the amp and at the head unit.
what are the specs of both the speakers and the amp
MrSo0h0o is offline   Reply With Quote
Old 12-16-2009, 05:29 PM   #6 (permalink)
View gameguru1360's Photo Gallery
also check the ground from the head unit as well. Possible loose ground at the head unit.
The ground at the amp's terminal could also be loose as well.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
