hi i have a Toyota sportivo Camry 2002 that i brought at toyota penrith and today i found that the radio is not working(picking up radio stations) everything else works fine.CD,ect but no radio . can you tell me if the radio antenna has a fuse and if so where could it be? or what could be another problem with the radio.
I suspect the problem may lie in loss of connectivity between the radio antenna (printed on my car’s rear window) and the audio unit (installed in dashboard area)
if this is so how can i fix it or how can i get to the connection.iv also put back in the first car radio i had with the car and no radio stations on that as well so that the radio tuner out of the question.as both radios i have cant pick up FM or AM reception.
thank you
