Toyota 2002 sportivo radio not working Please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2009, 04:52 AM   #1 (permalink)
View pythonsnake's Photo Gallery
hi i have a Toyota sportivo Camry 2002 that i brought at toyota penrith and today i found that the radio is not working(picking up radio stations) everything else works fine.CD,ect but no radio . can you tell me if the radio antenna has a fuse and if so where could it be? or what could be another problem with the radio.
I suspect the problem may lie in loss of connectivity between the radio antenna (printed on my car’s rear window) and the audio unit (installed in dashboard area)
if this is so how can i fix it or how can i get to the connection.iv also put back in the first car radio i had with the car and no radio stations on that as well so that the radio tuner out of the question.as both radios i have cant pick up FM or AM reception.And another question is question is how can i find where the anntenna wiring is so i can check to see if the connection's have not come lose. As the antenna has to come from the back window to the stero some how.
please help as i cant go with out my FM for to long.
so it has something to do with my antenna. or is there a fuse some where that run's the antenna
thank you
thank you
pythonsnake is offline   Reply With Quote
Old 12-11-2009, 05:09 PM   #2 (permalink)
View dr_green's Photo Gallery
thank you
thank you
did you get your windows tinted? Sometimes when people tint their windows, they damage the antenna on the rear window. Also there should have a FM box in the rear pillar, i think the left side. you might be able to check that out, but i'm not to sure what's the deal in there. good luck!
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
Old 12-11-2009, 05:55 PM   #3 (permalink)
hi thanks for reply i will let you know about the FM Box and no i didnt tint the windows.working one day and then nothing.
what a pain.
Old 12-12-2009, 09:20 PM   #4 (permalink)
View sienna1's Photo Gallery
Canada
Most glass mounted antennas require an amplifier to acquire a strong enough signal. Make sure that there's 12V to the antenna's amplifier if installed. See http://www.supraforums.com/forum/sho....php?p=6175963 for reference to different configurations.
sienna1 is offline   Reply With Quote
Old 12-12-2009, 10:42 PM   #5 (permalink)
thanks but all is connected right i just cant under stand why it was working one day and not the next.i have also replaced the FM box on the back window but that did nothing .there has to be something els that we are missing
