Originally Posted by sleep_deprived129
the only thing my amp says is that the impedance needs to be 4 ohms or greater for bridged connections or 2 ohms or greater for stereo connections, am I understanding correctly that it means this kinda connection will not be an issue?
it shouldn't be an issue. most 2 channel amps have tri mode which is being able to power 2 coaxial or 2 component speakers and a sub at the same time.
Whenever you bridge 2 channels the minimum impedance is 4ohms on a 2 channel amp. Most 2 channel amps are stable at 2ohms.
Never wire subs to where they're lower than what the amp supports, otherwise you'll not only damage and ruin the amp, but you might also damage your other electrical components like the alternator or battery or computer chip.
