Adding Sub to Camry SE 09 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2010, 07:44 AM   #1 (permalink)
View bearclaw1017's Photo Gallery
Hey guys,
Thought about adding a sub to my SE 09 (JBL). I know nothing about audio but is it even possible? Is it possible with the standard head unit or do I need to find a new one? From the research I have done, it seems possible with the built in head unit with just the sub, amp and a few cables.
If not, what new head unit do you guys recommend?
Thanks for all your help.
bearclaw1017 is online now   Reply With Quote
Old 01-21-2010, 06:58 PM   #2 (permalink)
Biggg72's Avatar
View Biggg72's Photo Gallery
its completely doable. all you need is your amp for the sub, your sub and box, a in line converter, and a amp wiring kit. tap your 2 reart speakers for the signal, run your rca's, run your poweer for the amp hook up the speaker wire and there you go.
Biggg72 is offline   Reply With Quote
Old 01-28-2010, 11:58 AM   #3 (permalink)
View gameguru1360's Photo Gallery
most aftermarket head units have rear rca inputs for front, rear, sub. It might be easier to go with an aftermarket head unit, get an amp installation kit and hook up directly to the aftermarket. If you stick with the factory head unit that was posted earlier, you can still hook up an amp by tapping into the rear speaker leads. A little tricky if this is your first time fiddling around with car audio.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
