I need a new amp, any suggestions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2004, 07:36 PM   #1 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Just to start off i no my amp is crap so dont diss it, just help me choose a better one
I have a 600 watt Legacy amp 2 channel. Doesnt do my Rockford Subs 10" and justice. Sounds really bad, i go in my freinds car he has one and the thing hits harder than my two.
I have two 10" subs max 400 watts max
what would be a more suitable amp, to get some power and make them sound better
I was thinking of getting a rockford amp, or clarion
any suggestions for my application
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 03-08-2004, 09:01 PM   #2 (permalink)
View JaJay721's Photo Gallery
What ohm rating are the subs listed at?
JaJay721 is offline   Reply With Quote
Old 03-08-2004, 09:37 PM   #3 (permalink)
Go camry goooooo
DrewsCam's Avatar
not to sure, um will this help
150 rms and 400 peak
Old 03-08-2004, 09:41 PM   #4 (permalink)
View rawdawg's Photo Gallery
What kind of box are your subs in(if they are at all) and what kind is your friends set up in?
1988 Camry
Occasionally washed
rawdawg is offline   Reply With Quote
Old 03-08-2004, 09:50 PM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
heres the pixs of my box, theirs is similar but one sub
Old 03-08-2004, 10:06 PM   #6 (permalink)
I need a model number off that amp or the sub. I think I know what amp you have but I want to make sure. Can you get a model number for me? Rockford makes two low end 10" subs in either 4 ohm or 8ohm configurations. You can't tell which is which by looking at the cone.
Did you install this yourself?
And upgrading your amp probably won't be enough to hit harder than your friend. Do you know what setup he has?
Old 03-08-2004, 10:23 PM   #7 (permalink)
Go camry goooooo
DrewsCam's Avatar
Rockford 10" punch z
rfz3410/3810
and the amp i cant find its paper work
nah i didnt do the install, but i no how to now, so i could easily put in a new amp
Old 03-08-2004, 10:25 PM   #8 (permalink)
If all you're doing is an amp swap you should have no problems. Anyone who can change a lightbulb can figure that out. Did you pay for that install work?
I'm looking up the info now...
How much you looking to spend?
Old 03-08-2004, 10:29 PM   #9 (permalink)
The RFZ3410 is a 4ohm woofer and the RFZ3810 is an 8 ohm woofer. You have one or the other not both. The amp may have the model number written on it somewhere.
Old 03-08-2004, 10:51 PM   #10 (permalink)
Go camry goooooo
DrewsCam's Avatar
id said its the 4 ohm, its not top of the line
Old 03-08-2004, 11:06 PM   #11 (permalink)
One isn' t better than the other. They're the same price and will sound the same when powered correctly. Rockford makes them in two models.
If you have two 8ohm woofers then most likely you have an amp that is bridged at 4ohm to run them and that's how we would want to run them again so you can reinstall easily. This is what I think they most likely did.. but I'm not too familiar with the legacy line and if they have changed their amps year. We really need to know which model amp or subs you have before I anyone can help you. I don't want to guess as to what you have.
I think this is your amp, but I'm not sure...
Amp
Old 03-08-2004, 11:12 PM   #12 (permalink)
Go camry goooooo
DrewsCam's Avatar
thats it!!
Old 03-09-2004, 09:15 AM   #13 (permalink)
If the LA470 is your amp then it's wired bridged at 4ohms and you have the 8 ohm speakers. You need to find another amp that can be bridged to produce roughly 400 RMS. How much are you looking to spend?
Old 03-09-2004, 10:38 AM   #14 (permalink)
Go camry goooooo
DrewsCam's Avatar
Um about 200 or so, not now any ways. Gotta spend money on the kit now
Old 03-09-2004, 12:42 PM   #15 (permalink)
I know Rockford(if you want to keep it all the same) sells a 400 watt bridgable amp I think the 401S for about $175. I'll check into some other brands and see what I can find.
