lil more help with sub decision... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2004, 01:25 PM   #1 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112950
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I have a Kenwood KAC 7295 600w amp and I'm looking at replacing my blown HE2 Dual 4ohm 800w max sub with a new HE2... Should I go with the Dual 4ohm or the Dual 2ohm? Whats the difference? Which would be better with my amp?
4ohm
http://www.sounddomain.com/sku/ROCRFP4210
2ohm
http://www.sounddomain.com/sku/ROCRFP4110
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 03-09-2004, 02:24 PM   #2 (permalink)
View JaJay721's Photo Gallery
Do you mean the 729S? If so you want the dual 2 ohm
JaJay721 is offline   Reply With Quote
Old 03-09-2004, 02:31 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700865
iTrader Score: 6 reviews
View EKam's Photo Gallery
That amp is too weak for that sub.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 03-09-2004, 02:32 PM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
lol. yes.
why the 2 over the 4? whats the difference?
Old 03-09-2004, 02:41 PM   #5 (permalink)
The way you wire it up, it has two voice coils which means you have to wire them up in series or parallel. When you do so it either drops or raises the ohm rating. If you had two 4 ohm voice coils your only options to run the speaker would be 8 or 2 ohms. You need the 2 ohm because then you can either run it at 4 ohm or 1 ohm. Your amp's 99% likely wired up bridged unless the installer was the dumbest dipshit ever and so that means it's putting out a 4ohm load. If you're only going to run one speaker you want a 4ohm load to match up to how your sub is currently wired.
Old 03-09-2004, 02:49 PM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
ok. I understand that much. I definately want the 2ohm, right?
The installer was a friend... aka dipshit
How should I wire up the 2ohm HE2? what to what and where to where, I'm a audio noob.
Option 2?
Old 03-09-2004, 02:51 PM   #7 (permalink)
see above..edited the post while you were posting.
Old 03-09-2004, 02:52 PM   #8 (permalink)
yes.. took down my image cause yours is easier to see.
Fuck it I'll put it back up, it might help.
Old 03-09-2004, 03:00 PM   #9 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Sweet! Crash course in audio 101 successful.
THANK YOU!
...the kid who installed it had it in his car wired like that but to both sets of terminals? any idea what he was going for? or was he a dipshit?
Old 03-09-2004, 03:02 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
So I just connect those other two together on their own?
Old 03-09-2004, 03:04 PM   #11 (permalink)
Not sure what you're asking. Check your PM to see if what I sent you helps.
Old 03-09-2004, 03:07 PM   #12 (permalink)
Waiiit a minute. I just re-read your first post. He had that amp running a dual 4 ohm sub? Ok he was a dumbshit. Ignore what he did.
Old 03-09-2004, 03:27 PM   #13 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
lol. So its +amp to +sub terminal A and -amp to -sub terminal B and +sub terminal B to -sub terminal A
