New Setup. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2010, 06:17 AM   #1 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
USA New Setup.
Got the system installed while I am waiting for the parts from my accident to get here.
Alpine M650 Class D Mono Block Amp. - Paid $288.10 Brand New (side mount on box)
Kicker CVR12 Sub - paid $50 for, lightly used. Wired in 2 ohm mode for max power (This is an older version, but the cone is made of a nylon woven material, that is EXTREMELY DURABLE)
It sounds great. (Its just for bass, I listen to alot of dance and house music)
That is a Scosche 12 Sealed Box, that I am going to port with a single 5inch hole on the top, The box, JUST meets the ported guidelines at 1.75. (I already have the port tube insert too)
I have some aftermarket Pioneer 6,5's to go in the rear deck when I stop being lazy.
Front of the box.
Side of the box.
Top of the box, where I am going to drill 2 5inch holes with a hole saw bit.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 02-15-2010, 01:25 AM   #2 (permalink)
If any of you cared - here is a video
Corolla Number TWO
Old 02-15-2010, 09:49 AM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
i wouldnt keep that amp mounted on the box.. vibrations can do a lot of damage to the amp's components.... and in your video i sure hope your gain and bass boost arent that high.. if they are, you wont have that amp and sub for very long
MrSo0h0o is offline   Reply With Quote
Old 02-15-2010, 09:56 AM   #4 (permalink)
I only had them on that high for the test. The system is built for bass, but after that video was done, I turned them back down.
Corolla Number TWO
Old 02-15-2010, 12:29 PM   #5 (permalink)
View gameguru1360's Photo Gallery
also for security reasons, you probably want the amp separate. If someone steals your box, they win hands down as your good sound system just went out the window!
yep the vibrations would probably kill the internal components, not to mention the wiring or connections...maybe vibrate the connections so much that they go loose!
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 02-15-2010, 02:37 PM   #6 (permalink)
Old Fart
mmasse's Avatar
Gameroom cash: $261903
View mmasse's Photo Gallery
Unless you added braces in the box for Amp support the vibrations are going to kill that amps life cycle as already mentioned. Plus portability means its a one stop shop for thieves. I would mount the amp in the trunk as opposed to the box.
I carry a gun because a cop is too heavy.
mmasse is offline   Reply With Quote
Old 02-16-2010, 02:55 PM   #7 (permalink)
usually most people mount it on the back of the rear seats and ground it to one of the bolts which is conveniently located towards the bottom of the seat
Old 02-16-2010, 03:03 PM   #8 (permalink)
except when I want to adjust it, I will have to completely remove the back rest of my seat to adjust it...
Corolla Number TWO
Old 02-16-2010, 05:40 PM   #9 (permalink)
MrSo0h0o's Avatar
if you tune it properly the first time, you wont need to do any adjusting
Old 02-16-2010, 05:47 PM   #10 (permalink)
maybe i want to adjust it on the fly or I have OCD? Everyones taste is different.
Corolla Number TWO
