Amplifier Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2010, 01:26 AM   #1 (permalink)
View waffles's Photo Gallery
4th Generation Amplifier Install
Hey guys, I recently got subs for my Camry and I've gotten everything wired except the power. Problem is I can't find a hole on the drivers side firewall to pass the cable through. I searched first for an answer and I got this.
Originally Posted by touringcamry View Post
Pull the front driver side wheel off and remove the plastic liner. You'll see a rubber grommet with a bundle of wires going through the firewall and then going up through the wheel well into the engine bay.
I've seen the grommet myself, but I had a question, is there another way, because taking off the wheel is such a pain. Also, if I take the wheel off myself, and then put it back on, will I run into any problems with loose bolts or anything? Because usually they're put on with a torque screw right? Also, for grounding the amp, where is the closest bolt?
waffles is offline   Reply With Quote
Old 02-27-2010, 01:40 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You can always drill a hole if you don't want to use pre-existing ones.
What is a torque screw? Do you mean a torque stick used in conjunction with a pneumatic impact gun?
For Toyotas, the wheel is held on by usually by at least 4 lug nuts -- I have no idea what car you are working on. These need to be torqued to about 80lbs in a star pattern. YOu can use the wrench provided in the trunk with it's a bit of effort required because it is short.
I grounded my amp to one of the bolts that holds side seat piece down. I thought about using the same one that fastens the seatbelt but decided that wasn't something I wanted to mess with.
2007 Camry 2.4L 5M
Old 02-27-2010, 01:50 AM   #3 (permalink)
I think I'll just take off the wheel, saves me the gas and money to buy a metal drill bit and then taking the risk of drilling into something. But once I take off the wheel and open up the liner, I should easily be able to feed the wire into the cabin right? Oh and what I meant about the torque screw (lol) is just how they tighten lug nuts at a shop, sorry I'm really tired. I'll be probably doing this by hand from the tools in the trunk.
Old 02-28-2010, 10:43 PM   #4 (permalink)
View frojoe's Photo Gallery
Not easily, but you'll be able to do it. I grounded mine under the seatbelt bolt. Wherever you ground make sure you take off the paint to get a clean connection.
frojoe is offline   Reply With Quote
Old 03-03-2010, 05:36 PM   #5 (permalink)
View gameguru1360's Photo Gallery
and make sure it is TIGHT on the bolt end and at the amp!
I found it the hard way where the ground at the amp terminals came loose and it created a loop which blew out my alternator fuse. And it was a bitch to get to in order to replace because the 100a alt fuse is like a tooth!
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 03-05-2010, 11:28 AM   #6 (permalink)
View dr_green's Photo Gallery
there is a passage way on the passenger side. I passed my cables throught the passenger side. You should be able to find a way on that side too.
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
