Running wire through glove compartment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2010, 12:34 PM   #1 (permalink)
View G4LE00's Photo Gallery
4th Generation Running wire through glove compartment
OK, so i recently installed my Pioneer DEH-P4100UB in my 00 Camry. I am thinking about running the usb wire from the back of the radio and into the glove compartment. But my question is, is are there any moving parts behind the glove compartment? And can running it through there possibly mess with wires or anything for the airbag, causing it to malfunction?
G4LE00 is offline   Reply With Quote
Old 03-07-2010, 01:29 AM   #2 (permalink)
View pancit175's Photo Gallery
You should be fine, although You should always look at first. If there happens to be any moving parts like the mechanisms for the ventilation the best thing to do is just zip-tie the cable down so it doesn't have much play. And there is no danger of messing with the airbag so long as you don't go messing with random wires or plugs.
pancit175 is offline   Reply With Quote
Old 03-09-2010, 11:34 AM   #3 (permalink)
View dr_green's Photo Gallery
i have a jvc dvd deck and my usb wire is in my glove box. I hardly use it though. It's not as convinient as I thought it was. I think some where along like the arm rest in the middle is a pretty good location for the usb wire. Plus if you run it there, there is a cigarette lighter there, so u can charge or run your device if you need power. Good luck!
JVC KW-AVX810 DVD DECK(RUNNING BACK 6X9'S AS REARFILL); MB QUART REF. SER. SEPARATES (TWEETERS); ROCKFORD FOSGATE PUNCH 100X2 (FROM 1997, RUNNING THE HIGHS) RATED @ 498W RMS BS; KENWOOD EXCELON X1200M AMP (RUNNING SUBS) PAS MAG TESTED @ 1324W RMS @ 2 OHMS; 2 ALPINE TYPE R'S 12" IN RGW PORTED BOX.
dr_green is offline   Reply With Quote
Old 03-10-2010, 10:16 AM   #4 (permalink)
Thanks for the info guys! Just wanted to make sure....I did think about running it through the armrest, but i didnt want to have to take anything apart.
Old 03-10-2010, 02:51 PM   #5 (permalink)
View Exit9's Photo Gallery
If you search the forum there is thread on radio removal which has photos of how to start taking the floor counsel apart and also on how to remove the glove box. The procedures are easy once you see the pictures. I removed the glove box and drilled a hole from the top to route and amplifier remote control inside the glove box. I don't recall anything that moves behind the glove box. I ended up routing wires through tie loops hanging from the back corner glove box supports.
Exit9 is offline   Reply With Quote
