'89 Camry Dash Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 10:20 AM   #1 (permalink)
View Puma Man's Photo Gallery
Question '89 Camry Dash Removal
Hey, I'm trying to remove my dash but I can't figure out how! I'm doing the passenger side first, and I must have removed every screw connecting the dash. I even removed the glove compartment door, but can't seem to remove the actual glove compartment. Should I just grab onto the back of the dash and pull really really hard? I tried searching google for a while, but I couldn't find anything helpful.
Puma Man is offline   Reply With Quote
Old 03-15-2004, 03:34 PM   #2 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
which part of the dash? the whole top part or the bottom? takin off the bottom is easy, to take off the whole top then that will take a bit longer and is very timely...if you want a good idea as phatle91 (i think thats his name), he's done a whole swap on his dash...other wise just tell us what your doin and what part of the dash you are tryin to do.
re-read ur post...so have you taken out the glove compartment or just the front panel on it....this shouldnt happen....to take off the glove compartment, just remove the 2 screws underneath it that go through these lil plastic like tabs that are joined to the glove box. on the picture below it is the 2 red dots. after that grab the handle as you would to open it and pull it forward until it is right out then pull up a bit...if this doesnt work tell me and i'll check again...
Huy
1989 BEAMS 3S-GE SV21 Camry
2003 ST246 Caldina GT-Four N
da_horse is offline   Reply With Quote
Old 03-15-2004, 04:19 PM   #3 (permalink)
I guess I should have said *why* I'm trying to remove the dash. I'm trying to install new speakers in the front. But hey, I'll try what you said.
Old 03-15-2004, 04:45 PM   #4 (permalink)
Beams SV21
da_horse's Avatar
new speakers eh?
ok you'll need to take off a few more....there might be afew clips too....shit...i'll have a look for you later but there are about 10 screws if that....hard to remember....give the dash area around the glove box a lil tug and if part of it moves just check whcih is holdin it back and if you cant see a screw then it might be a clip....
see how u go and get back to me later....i havent got the car atm...
all the best
Huy
Huy
Old 03-16-2004, 03:16 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The glove compartment is held on with a few screws. 2 at the top and 3 on the bottom if I remember correctly.
Did you remove all the bolts for the dash? Theres 4 at the bottom (2 on each lower corner). I think theres 1 behind the speaker grill too.
"Skoolin' the unlearned!"
