Gen 3 Keyless - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 12:22 PM   #1 (permalink)
View RSCD_HireD's Photo Gallery
Gen 3 Keyless
i was looking at some alpine alarms but not sure if it has keyless.....it says "Door Lock/Unlock Outputs" but does that mean it will actually unlock/lock door? or do i need to buy more parts to enable that option......
My Ride
2005 Camry LE
RSCD_HireD is offline   Reply With Quote
Old 03-15-2004, 12:42 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Yup, that should unlock/lock your doors....
The only thing you MIGHT need is a relay if the alpine unit doesn't reverse the polarity for the door unlock/lock button. Some door locks need a postive signal to unlock the door, some use a negative signal. Some alarm units will allow you to configure this on the unit (most do), I assume the cheap ones won't. You should be ok with the Alpine, but a relay is only $5 anyway.
Silver Streak is offline   Reply With Quote
