2008 Corolla S Audio Advice please? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2010, 03:30 PM   #1 (permalink)
View Terra517's Photo Gallery
Hi there!
I've been looking into getting something installed in my car that would allow me to play my ipod or zune. I went to my local bestbuy and saw the iSimple-Adaptor Model: IS77 | SKU: 9252122At first I was looking into the Factory version for iSimple that Bestbuy sells but found out from one of the guys at the car installion part of BestBuy that my car doesn't have something so they can't install it. (PS: I have the factory stereo in it)
I'm wondering if anyone can advise if that model might be recommended. It seems like BestBuy has a list of reviews but it's all mixed...so maybe someone else here might be able to advise?
Or should I just have a new radio installed and if that's the case what would everyone recommend?
(I worried about buying that iSimple product and not really having CD quality music in my car....)
Thank you in advance everyone!
Terra517 is offline   Reply With Quote
Old 03-16-2010, 01:14 AM   #2 (permalink)
View pancit175's Photo Gallery
That part is just a wired FM modulator. When installed correctly, when its switched on it will bypass the frequency used and feed the signal from the connected device directly into the radio via the antenna. The benefit of a Wired FM mod as opposed to the Wireless FM mod is that wireless has no defense against interfering signals and is typically not that strong of a signal output.
Benefits:
-that specific device uses a cable with either the ipod dock connector or 3.5mm headphone jack, (not both without additional parts or work)
-It can charge your ipod when using the ipod dock connector cable
-keep your factory HU
-good signal given from your device to your factory radio
Disadvantages:
-that specific device does NOT allow your factory HU to control your ipod
-you have to tune your radio to a specific station when in use
-if you don't turn it off it will interfere with your radio reception
-you keep your factory HU
Assuming you are not an audiophile, this is all you would need if you want to keep your factory equiptment. You may not even notice much of a difference in quality. If you are an audiophile, even in the slightest degree, then you probably wouldn't even consider keeping any of the stock equiptment, let alone need to consider this device.
Personally I think all stock audio equiptment is crap, but you would get more features/options/performance out of aftermarket equiptment than stock. But if you really want to keep the stock radio or don't have the cash to go aftermarket than something like that piece should be adequate.
pancit175 is offline   Reply With Quote
Old 03-16-2010, 12:53 PM   #3 (permalink)
Thank you! I think I'll defiantly try it out then and if its not what I expected only then I'll think about getting a new radio... I actually like the factory stereo so I'm hoping I won't have to replace it.
(I'm not into getting a new radio b/c I'm worried it won't look good inside the car and the color theme might not match with the rest of the car...but if I have no choice....)
This helped! Thanks again for all that information!!
