Originally posted by epborden
Unfortunately the rear speaker mounts of mine were too bent to be used again. I'm still trying to figure out a way to fit the better speakers in.
Heres an idea that i've actually used before on a gen 2 that came into the shop that I use to work at.
1. Remove the top half of the speaker grill. Just pop off the 4 little circular clips (refer to the pics I posted) on the underside of the grill. Then pop the top half of the grill out.
2. Use the top half of the grill (the piece you popped out) as a template and trace it out onto a piece of 1/4" plywood or mdf.
3. Cut out a hole for your new speaker, mount the speaker to the backside of the piece of wood, and cover the whole thing with grill cloth.
You can also mount the speaker to the top of the piece of wood if you want.
4. After you get it mounted the way you want, drop it back into the other part of the stock speaker grill.
You'll want to glue the piece down and/or use some really small screws to secure the piece.
I used liquid nails (we have a bunch of it around the shop).
