Gen3 Radio Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2004, 06:58 PM   #1 (permalink)
View luisitol's Photo Gallery
Gen3 Radio Install
Hey guys,
sry for the noobish questions. I'm pretty sure the install is straight forward, but i just wanted to double check. I"m instaling a new head unit on my Gen 3 93 LE and i was wondering if there were any tips or how tos out there. I did a quick search but came up pretty empty.
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 03-28-2004, 09:31 AM   #2 (permalink)
No Fat Bitches
iTrader Score: 10 reviews
View PtBaller's Photo Gallery
These sites should help http://www.carstereohelp.com/stereoremovalToyCamrya.htm
http://rayrayonline.bravehost.com/headunit.htm
^ Volk Racing CE28s 19x8.5/8 for sale
PtBaller is offline   Reply With Quote
Old 03-28-2004, 03:44 PM   #3 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
tools....philips screwdriver, flat putty knife...take the knife and pry the center u-shaped plastic piece round the h/u and remove...2. then unscrew the four screws on the h/u bracket located in the din....remove h/u and take it out of the brackets...insert new h/u and work your way back
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 03-29-2004, 09:19 AM   #4 (permalink)
thanx guys i wasn't able to get back to the computer to check it out but the install went smoothly. Got the U-Shape trim off, then unplugged the lighter, took out the screws and then luckily i had bought a special harness from scoche to fit toyotas, i used the splice connectors so that i didn't have to cut any wires andmatched up the colors and then worked my way back. I'll have pics up soon.
Old 04-05-2004, 05:57 PM   #5 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
If you want your H/U to fit flush like a factory deck, you'll have to make some custom mounts for it too...only takes about 30 minutes with a Dremel, ruler, and some sheetmetal
BenG is offline   Reply With Quote
Old 04-05-2004, 06:16 PM   #6 (permalink)
No custom mount needed; mine bolted right onto the stock mount, it had holes marked for Toyota/ Nissan Vehicles
