first you need to figure out where your going to mount your amps, how much cubic feet you need for your subs, and if your going to use the tire well or not. you want to use mdf for your basic structure then cover it on speaker grill cloth. after that all is left is to cover it with fiberglass, sand it down, and either paint it or have it covered in your choice of material. the fiberglass will be the hardest part, i suggest you get someone who has worked with it before because if you have never used the material you might just end up making a big mess, trust me Ive seen it happen.
