i want my trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2004, 03:38 PM   #1 (permalink)
z168's Avatar
View z168's Photo Gallery
i want my trunk
i want to keep my trunk so i was planning to install pre-amplified bazookas or at most free airs. a friend of mine is saying im better off with a box or no subs at all.
do you have any suggestions?
z168 is offline   Reply With Quote
Old 04-20-2004, 04:07 PM   #2 (permalink)
So.Cal 99 camry
BILLSHEA99's Avatar
View BILLSHEA99's Photo Gallery
if you mean trunk space.. no subs would be the way to go ..
upgrading the interior speakers with a small amp under the seats will give you good sound quality, not much bass but .. wat are you looking to achieve???
mad ass shaking bass???
or
crystal clear crisp music???
having a box in my trunk pretty much killed half my trunk space so it's really up to you.
Team 13Devils CF CAMRY
BILLSHEA99 is offline   Reply With Quote
Old 04-20-2004, 04:21 PM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Mount your amp to the back of the seat and put a good connector in your lead from the amp to the sub. Then you can remove the bulk of the system when you need to
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 04-20-2004, 04:31 PM   #4 (permalink)
So.Cal 99 camry
BILLSHEA99's Avatar
true true.. that's wat I did, it's kinda of a hastle at times though
you have to expect when your gonna need that trunk space.. so you can leave the box at home...
Old 04-20-2004, 04:41 PM   #5 (permalink)
Audiophile on a budget
View TakeABao's Photo Gallery
Yeah, don't go with the amplified bazooka tubes...they're crap. Expensive and don't sound good at all..
/////ALPINE | Helix | SOUNDSTREAM
TakeABao is offline   Reply With Quote
Old 04-20-2004, 05:12 PM   #6 (permalink)
View rawdawg's Photo Gallery
You could go with an Aperiodic Enclosure. They take up about the same depth as the woofers. They do require expert installation. Since you're in SoCal, I can point you towards a shop.
Another solution is to take out your spare tire and build a sub enclosure in the well. Very trick and everything looks stock. You'd be best to have AAA, though.
There's nothing wrong with Free Air, especially if you're concerned with SQ.
What kind of bass response are you looking for? Are you a music lover or do you want to pound the neighborhood concrete without regard to accuracy?
One last suggestion. Subs do not neccesarily have to go in the trunk. With a little thought, there are many places one can fit a sub.
1988 Camry
Occasionally washed
rawdawg is offline   Reply With Quote
Old 04-20-2004, 07:23 PM   #7 (permalink)
bma
Banned
View bma's Photo Gallery
The best way is to raise your trunk and put the sub in the spare tire section. The job is pretty simple. I can help u do it for $800, the outcome would be a nice custom trunk.
bma is offline   Reply With Quote
Old 04-21-2004, 09:28 PM   #8 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
if you just want to round out the frequency range and add a little bump, you could use a Kenwood w00x or 2. I heard them in a jeep and it sounded pretty good. much better than a bazooka.
if you dont know what a w00x is, its a tiny sub, like 6.5"? with a funky designed case that amplifies the sound waves. the whole thing is self amplified and hooks up just like a regular amp.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-22-2004, 03:00 AM   #9 (permalink)
z168's Avatar
ive never had a flat in my life (that required changing the tire) but i still want to keep the spare tire.
yes i need trunk space and yes im more concerned about SQ but a little thumping wouldnt hurt since i listen to a lot of jazz and RNB
so that settles it bazookas are out
hmmm... amplify by current setup?... maybe just upgrade d rear deck speakers? (ive a 99 camry LE speakers still stock)
w00x? if you can send links pls post.
thanks for all the imputs
Old 04-22-2004, 12:57 PM   #10 (permalink)
View drdrew's Photo Gallery
Sup guys, This is what i did in My 97' camry I put high powered components up front and some high powered 6X9's in the back and a 4 channel amp to power all of this, you still got a Trunk and it sounds great, it's elegant and has Quality Sound !
if someone really wants more Bass, then fiberglass a 10" or 12" on the left side (i'm working on that )
drdrew is offline   Reply With Quote
Old 04-23-2004, 08:25 PM   #11 (permalink)
z168's Avatar
nice amp drdrew! whats the rating/power on that amp?
Old 04-24-2004, 04:31 PM   #12 (permalink)
Amp Rating
It's A good Amp, i like it !
Maximun Output: 900 Watts, 4 Channels
Low Pass Filter: 40Hz - 150Hz
High Pass Filter: 80Hz - 1.2kHz
Freq. Resp.: ± 1dB@5Hz - 50 kHz
Signal to Noise Ratio: >100dB
Stereo Separation >80db
Input sensitivity: 200mV-3V
Input impedance: 22k ohms
Op. Voltage: DC12V
Speaker Imdepance @ Stereo Driven: 4 Ohms
Fuse Rating: 40AX1
Brigdeable into 2 channels
Low THD-built amplifier engineering
Variable active crossovers
http://www.rrg.ca
Old 04-24-2004, 06:18 PM   #13 (permalink)
bma
Banned
Nice how much is it ? And what brand is it ?
Old 04-27-2004, 09:42 AM   #14 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
how bout getttin "free air" subs...mount them on a board....no box req'd...i have 3 tens and 2 eights in my AE86 coupe.....amps mounted on the side.....still have full trunk space......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-27-2004, 12:41 PM   #15 (permalink)
bma
Banned
I say free air woofer will not give enough bass. I used to have 2 10"mounted on a board. The bass is not as solid as in a box. Looks & spaces wise is good, but if u goin to put so many sh!t in your car. Might as well go for the best result right ?!
