Well, check with the warranty first. Your friend may luck out in that it's still under warranty.
For the ribbon cable, there is usually a clip holding it in the socket, so you'll have to unclip it from both sides GENTLY. The clip doesn't need to be completely removed for the ribbon cable to be released, but just enough.
If the radio needs to come out, just note the serial number down and the anti-theft code can be retrieved from the dealer; $35 doesn't seem too bad.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
