Bought (2) 12" 2004 L7 KICKER...Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2004, 03:12 AM   #1 (permalink)
All Show But No Go!
View Eniffey's Photo Gallery
Just bought:
* Pair of 12" 2004 Kicker L7's
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 75-750 watts RMS (375 watts per coil)
peak power handling 1,500 watts
sensitivity 86.6 dB
top-mount depth 6-11/16"
* NEW 2004 VX1400D Planet Audio
MONOBLOCK CLASS-D Amplifier
Max Power (1 Ohms) : 1250W X 1
Max Power (2 Ohms) : 1000W X 1
RMS Power (2 Ohms) : 825W X 1
RMS Power (4 Ohms) : 500W X 1
Signal-to-Noise Ratio : 100dB
Frequency Response : 20Hz-250Hz
Dimensions : 10-5/8”W x 2-7/16”H x 16”L
* Rockford Fosgate 500x for speakers
* Power Acoustik 2.4 Digital Farad
* 1.25 Sealed Cubic Feet Box
* Voodoo Distribution Block
QUESTIONS
How should I set this system up?
Cross Over - Bridge them? What ohm to run? Help please. Step by step if possible? I also have Rockford Fosgate 500x for my speakers. How do I put this system together for the best outcome. Also, do you think that the amp i bought is to weak for the subs? What would be better? Thanks guys!
- 05 4Runner
- 99 Lexus GS300 Custom (New Toy)
- 95 Camry V6 LE ****SOLD****
- 94 Lexus GS300
Eniffey is offline   Reply With Quote
Old 05-10-2004, 04:42 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
From what you posted about the amp, I would wire it up for 1ohm. That would give you the most power.
Wire the coils on each sub in parallel, then parallel the 2 subs together. This will give you 1ohm.
"Skoolin' the unlearned!"
Old 05-10-2004, 06:31 PM   #3 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
Dual 4 ohm subs mean that when you hook it up, its going to be either 8 or 2 ohms. You have two of these subs, so the it will net a 4 ohm load. Since a mono block amp is most efficient at 2 ohms (since that amp isnt 1-ohm stable) a mono block amp wouldnt be as good of a choice as a two channel amp.
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 05-10-2004, 08:32 PM   #4 (permalink)
Luc
View Luc's Photo Gallery
What?
He has a PA mono-amp capable of 1-ohm, and you're saying that a 2-ch amp is better? You're asking a 2-ch amp to run at 0.5-ohm stereo? I don't think even the old school Orion 225 HCCA can run that load.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 05-10-2004, 09:33 PM   #5 (permalink)
View JaJay721's Photo Gallery
The diagram 88 LE shows will work to get a 1ohm load. Dual 4 ohm voice coils means each sub is 2 ohm. Two 2 ohm speakers = 1 ohm or 4 ohm. And his amp is a Class D Planet Audio amp capable of 1ohm.
JaJay721 is offline   Reply With Quote
Old 05-10-2004, 09:46 PM   #6 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
Yeah, that JaJay said is right, if you have dual 4ohm subs... parrallel to 2 and 2... then parralel to 1 and 1
at first i thought what you said was goofy, but it is just what i was thinking
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 05-10-2004, 10:10 PM   #7 (permalink)
Wazzaaap!
I know I'm correct about the subs working perfectly fine with a 2-channel amp, so i dont know what Luc is talking about. And I did not know that the PA amp is 1-ohm stable. I even looked the amp up online and it does not say anywhere that it's stable at one ohm. It WOULD work perfectly fine at 1-ohm, but it sounds kinda sketchy to whether or not the amp can handle the load.
Old 05-11-2004, 04:39 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Thats only true for one sub.
Depends how you hook it up.
To get 4 ohms you would have to wire the coils on each sub in series, then parallel them together.
Edit: You can also wire the coils on each sub in parallel, then series them together. This will also give you 4 ohms.
Why is it that no one understands ohms law?
Old 05-11-2004, 08:22 PM   #9 (permalink)
Luc
You would rather use a 2-channel Class A/B amplifier getting about 50% efficiency in a bridged configuration rather than a 1-channel Class D amplifier getting about 85% efficiency?
Old 05-12-2004, 02:48 AM   #10 (permalink)
All Show But No Go!
Talking Thanks guys!
Thanks for the response guys so far. Don't think that I haven't read any of your replies and comments. Luc and Maui looks like they are getting it on. LoL! I will let you know how it goes and how I set it up. Keep posting for more input and ideas.
- 05 4Runner
- 94 Lexus GS300
