looking for electronics wizard - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2004, 10:55 PM   #1 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
I'm trying to install a PC into my car. I'm running into power issues. I don't want to use an inverter because it's inefficient/wasteful to convert 12v to 120v and then back to 12v again. So I plan to run the computer directly off the car battery. The problem is that PC's also require a 5v source.
So, does anyone know how to create a low-cost DC to DC converter, with 12v input, 5v output, with a minimum 20W of power?
I'm usually good at that stuff, but I don't feel like doing my own thinking right now.
Racing is everything
wedge is offline   Reply With Quote
Old 05-21-2004, 11:10 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
You can look into those LDO or switching regulators from Linear Technology or Maxim IC. For a 20-W 5V output, you'll need something that can output 4-A. Typically, if you follow the guidelines for using the appropriate capacitor and inductor parts, you'll get a steady output. For a 4-A output, those passive parts will be pretty big, typically, you want to allow some headroom. You can find something that has a dual output with a single input. For a switching regulator, do pay attention to the switching frequency because that may cause the output to fluctuate, thus, those passives must be used properly. FYI, a PC will need a 3.3V and -5V output as well for the ATX specification. So it isn't easy (or cheap) as it may seem.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 05-21-2004, 11:14 PM   #3 (permalink)
My Dixie Wrecked
wedge's Avatar
Thanks dude,
I'm just going to be running either a 486 or maybe a P1. Either of which run off a PS2 power supply. So there is no 3.3v output, and it will work fine without the -5v.
Old 05-22-2004, 12:48 AM   #4 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
i'm lazy and would just use an inverter......who cares if its inefficent.......i'm american, thats what i'm good at
alex is offline   Reply With Quote
Old 05-22-2004, 01:05 AM   #5 (permalink)
Luc
Thanks for you input. If you have something else better to suggest, please do.
Old 06-24-2004, 04:18 AM   #6 (permalink)
View ZXLNT's Photo Gallery
Also the inverters are not only inefficent the 110V they provide isn't the most clean. You dont want a lot of noise powering your computer..
Boston!! 100 Percent Guitar Driven Rock and Roll
99 Solara SLE 1MZFE
ZXLNT is offline   Reply With Quote
