97 corolla wiring diagram? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2004, 03:32 PM   #1 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $488901
View falnfenix's Photo Gallery
Exclamation 97 corolla wiring diagram?
hey guys...i'm in real need of help here. a friend of mine and i are going to install his alarm, but we can't find a wiring schematic for his 97 Corolla anywhere.
if ANYONE has one(i think it would work for 94-97 corollas) and can post it up as soon as possible i'd really appreciate it.
thanks in advance.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 05-29-2004, 06:59 PM   #2 (permalink)
View foompla's Photo Gallery
i can get one at work. can it wait until tuesday?
foompla is offline   Reply With Quote
Old 05-29-2004, 07:26 PM   #3 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
why do u need a wiring diagram? what kind of alarm is it? you only really need to attach 4 wires
power
ground
door light
ignition (only if you are installing a starter kill relay)
and for pwr dr locks you just have to pop the door panel off to see the wire color (safest way because the wiring diagram CAN be incorrect)
Hatch is offline   Reply With Quote
Old 05-30-2004, 01:50 AM   #4 (permalink)
Luc
View Luc's Photo Gallery
Uh..he needs a wiring diagram to know what POLARITY is needed. A starter kill is ALWAYS mandatory, otherwise, what good is it for an alarm? The starter wire needs to be identified also. Why take shortcuts? Don't do a half-arse job, do it right the first time!!!
Here is the wiring information.
12volts white + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Power Lock blue/black - passenger kick
Power Unlock blue/red - passenger kick
Notes: Green/white on models with factory alarm.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ green dimmer switch or kick
Parking Lights- lt. green or white steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger red/white or black - plug at top of fusebox
Notes: Use the Black in a 2 pin connector at the top of the fusebox on versions without a sunroof. On cars with a sunroof use the red/white in a 4 or 6 pin connector in the same location. When adding dome light supervision use the door trigger wire and relay isolate to keep ground from entering the fusebox side of the wire or unlock will not function properly.
Dome Supervision
Trunk/Hatch Pin red/white - light or pin in trunk
Notes: On the wagon version the rear door is tied in with the door trigger wire.
Hood Pin red - anti-theft ECU
Notes: The anti-theft ECU is located high in the drivers side kick panel.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black ac check connector
Horn Trigger green/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 05-30-2004, 03:16 AM   #5 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
THANK YOU!!
ಠ_ಠ
