4" Components (JayJay, Luc, etc) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2004, 12:35 AM   #1 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Well, I've decided 3-way components would be too pricey so I decided on sort of making my own 3-way system. What do you guys recommend for 4" components. I'm trying to keep the price under $200 but willing to go a little over. I think I'm pretty set on getting the 6.5" Image Dynamic midbass drivers for the doors.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 06-10-2004, 10:11 AM   #2 (permalink)
View JaJay721's Photo Gallery
MB Quart makes some nice component sets and they have a few 4 inchers. I've ran a set of 6.5"s, but to be honest I've never heard their 4" or any of these listed below.
CDT also carries numerous 4" sets.
I think Soundstream has the Exact series which go for around $225 and I believe they offer a 4" set.
I'm not too sure what Focal sells in the 4" line.
Good Luck.
I'm pretty sure Infinity, JL and Eclipse don't offer 4" sets off the top of my head.
Premier 860MP 6" Perfects 6x9 Kappas PPI480 Yellowtop Iraggi 180a Alt Viper 791XV
On the way: Directed 1500D Orion H2
JaJay721 is offline   Reply With Quote
Old 06-10-2004, 12:33 PM   #3 (permalink)
Stealth's Avatar
Took a look at the Soundstream Extreme series (Exacts are coaxial), they certainly are interesting. They have horn loaded tweeters. Also, they run at 3 ohms, but I think that should be fine since my amp is 2 ohms stable. I'll try to do some more research on these.
Focal and CDT speakers are just too deep for me. If Infinity offered 4" Perfects I wouldn't even have to make a decision. I guess I'll take a look at MB Quart, even though they're well known for their harsh tweeters. But then again, the Perfect tweeters don't bother me now.
Old 06-10-2004, 10:03 PM   #4 (permalink)
Luc
View Luc's Photo Gallery
Listen to the Boston Acoustics Pro 4.5 (not sure if it's available), but that line of speakers from them are pretty good. Don't think you want to spend money on the Z series. I believe there is a Rally 4" components also, cheaper, of course. For the 6.5 IM drivers, you may want to filter those using a bandpass configuration, then let the sub(s) do the rest.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 06-10-2004, 11:44 PM   #5 (permalink)
Stealth's Avatar
Thanks for the advice, I'll check them out. I'm going to set an HPF on the IDs at 60 Hz, and will set a LPF on them at about 400 Hz if possible. When I add subs, I want them to play from 20 Hz to 60 Hz. I'll probably get the variable Q Infinity Perfect subs since I can get them for cheap.
Old 06-12-2004, 04:34 AM   #6 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
I dont quite get how youre doing the crossovers without a 3-way crossover.
And for the speakers, I would try to keep it matched as much as possible. Different brands of speakers have different types of sound. Some brands/models sound duller or higher than others.
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 06-12-2004, 09:23 AM   #7 (permalink)
Luc
It would be nice to have a 3-way bi-amped crossover, but it's not necessary. For the midbass driver, the 2 channels on the amp would do the filtering. Brand coherence isn't a requirement at all, you can mix/match anything.
Old 06-12-2004, 11:40 PM   #8 (permalink)
View malukalu99's Photo Gallery
Some say MB Quart is too harsh, but I personally love them...I would get the Q-Series
They are handmade!! Beat that
malukalu99 is offline   Reply With Quote
Old 06-17-2004, 02:44 AM   #9 (permalink)
Stealth's Avatar
Hey JaJay or Luc, have you guys heard the JL components? 3-ways in particular? Their price isn't too bad and will fit my budget. My primary concern with them is how deep the speakers are.
Old 06-17-2004, 06:30 PM   #10 (permalink)
Never heard JLs in a car. I've heard quite a few sets on a wall. I don't remember model numbers or how exactly they sounded. I do remember thinking they were clean, but a bit overpriced like most of the JL line. I don't know how much power they were receiving, but I did like the sound even though I can't remember exaclty what they sounded like. I remember hearing full sound with a less dominant tweeter on all models. They all had the same sound type (if I remember correctly), but the higher end models had a better clarity. And come to think of it I haven't heard any of their three way systems, only 2 way. Sorry I couldn't be of much use to you. I tend to pay more attention to JL amps and subs than their speakers.
Old 06-17-2004, 10:36 PM   #11 (permalink)
Luc
Yes, I've heard the JL 3-way components, the 850CSi or something. That has been discontinued, unless there's a new 3-way set out that I'm not aware of. I don't think you'll have a problem with the depth on the "bass" driver, and they definitely give a more prominent presence overall. Of course, channel separation is pretty good.
The JL always had an in-between sound reproduction between neutral and harsh, so they don't sound flat or screeching. I tend to more of the neutral side, a flatter response on the frequency spectrum. But overall, the JL speaker systems, whether coaxial or component speakers have always sounded well to me.
Old 06-17-2004, 11:00 PM   #12 (permalink)
Stealth's Avatar
The model is the XR653-CS. They're from the XR line. I think the ZR line is better but they don't have any 3-way systems in there. Someone on another forum told me the depths were ~2.5" and ~2.25"
Old 06-18-2004, 11:02 PM   #13 (permalink)
Luc
Ok, that's the old model number, I don't know where I pulled that 850 number from...must have had some ...
Anyway, I did hear that before as I had described previously, and it's not bad at all, considering it retailed for about $800 then.
Old 06-20-2004, 01:49 AM   #14 (permalink)
Stealth's Avatar
Well, a little update.... "won" the Boston Acoustics Proseries 3-ways for $305+~$30 for shipping. So that's what I'm getting and I don't think I'll be dissappointed (cant spell right now). Not a bad price if I say so myself, since I saw a Buy It Now for them for $525.
