92 camy after-mkt stereo install, bypassing amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2004, 05:24 PM   #1 (permalink)
View maneesh's Photo Gallery
hi,
Now that I'm done with my alarm, I'm ready to install an aftermarket radio... I bought an Aiwa from crutchfield with the wiring harness. My question is how do I install it while bypassing the amp? The wiring ahrness from crutchfield came with two adapters. However, the stock radio was connected to one harness. I also noticed on the amp that there are two adapters connected to it.
Thanks,
maneesh
maneesh is offline   Reply With Quote
Old 06-30-2004, 05:54 PM   #2 (permalink)
View MonsterGrgXLS's Photo Gallery
If its anything like my shit box, then you have to cut the harness that goes to the amp from the speakers, and hard wire it to the deck. It was the only solution in my car.
MonsterGrgXLS is offline   Reply With Quote
Old 06-30-2004, 06:05 PM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
If you bought it from crutchfiel, they usually give you install instruction on how to bypass the factory amp.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 06-30-2004, 08:22 PM   #4 (permalink)
called crutchfield
Their tech guy said that there are two connectors in the back and I should connect these to those. I do recall seeing the two connectors when I removed the radio earlier....
However, I want to confirm that I can still get audio out of all the 6 speakers instead of the 4. Someone on another thread mentioned that the front tweeters are connected to the front speakers via a capacitor....
Thanks,
maneesh
Old 06-30-2004, 09:25 PM   #5 (permalink)
Got SQ?
eddiem67's Avatar
they are wired in series, the little cap is to block out lower frequencies that the tweeters can't handle. You should be fine.
Gen 4 V6
Old 06-30-2004, 09:37 PM   #6 (permalink)
Luc
View Luc's Photo Gallery
DO NOT cut the wire harness!!! To the right side of the cavity, there should be two mating harnesses wrapped in foam. Disconnect the end from the OEM amp, and connect your matching adapters there. All six speakers will work, the front tweeters are wired inline with the front speakers in the door.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 07-01-2004, 09:31 PM   #7 (permalink)
Completed the installation today... Very straight forward. Connected the harnesses that came from Crutchfield to the blue connectors in foam. I get audio from all 6 speakers.
Thanks,
maneesh
