8 ohms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2004, 10:56 PM   #1 (permalink)
View MYCARcamry's Photo Gallery
8 ohms
is it safe for most car amps to see a 8 ohm load or could they only run on 4 and 2 and 1 ohms loads safely?
MYCARcamry is offline   Reply With Quote
Old 08-01-2004, 11:23 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $358560
iTrader Score: 13 reviews
depends on what kind of amp it is and it's intended application.....
for 4 or 2 channel amps, they could be intended to be run at 8ohms b/c they usually aren't designed to be made for raw power but for mono blocks, they are generally made to be run at at least 4 ohms and *should* be still steady and not overheat at 2ohms
if you get a competition or at least a very good quality mono amp, it should be able to be run at a true 1ohm
best way is to take a look at the manual...
HaHa
Old 08-01-2004, 11:56 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
8 ohms is fine.
Lower resistance = more power, but you have to make sure your amp can handle it.
Higher resistance = less power.
"Skoolin' the unlearned!"
