1999 Solara Rear speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2004, 04:05 PM   #1 (permalink)
View Bugz_2005's Photo Gallery
Red face 1999 Solara Rear speakers
I need a diagrahm on how to change the rear speakers in a 1999 solara, Does anybody know ho wi can change them.
Thanks
Bugz_2005 is offline   Reply With Quote
Old 08-02-2004, 04:10 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
I haven't worked on a Solara but I don't imagine it's much different from a Camry or any other toyota for that matter.
Do a search using keywords "rear + deck + remove". Sift through the posts and you should be fine.
Are you replacing the stock speakers?
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 08-02-2004, 05:44 PM   #3 (permalink)
REAR SPEAKERS
YEAH, I blew them out...i am replacing them with some 600w boss 2 way speakers
Old 08-03-2004, 12:00 AM   #4 (permalink)
Luc
View Luc's Photo Gallery
IIRC, there's quite some work involved to get the rear deck out from the Solara. You'll need to remove the C-pillar panels to get the rear deck out which will also require the handle bars, bench seat, and rear armrests to be removed. The Camry had less work.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-03-2004, 07:57 PM   #5 (permalink)
Cello8619's Avatar
View Cello8619's Photo Gallery
if the solara is anything like my 3.5 coupe, you just have to remove the rear bench seat by lifting it straight up and then removing the side cushions that are next to the side arm rests. Then remove the stop lamp and the rear deck slides out. Maybe a 20min prodject tops to get to the speakers. The only think that is a pain is getting the rear bench seat out of a coupe.
1996 Green Camry DX Coupe with a 5 speed
Cam's Online Home
Cello8619 is offline   Reply With Quote
