Have you tried replacing the relay? Otherwise, you will have to trace those wires back to the ignition harness to completely remove the starter kill relay.
Here are the wires identification:
12 volts - white or black/red, ignition harness
starter - black/white, ignition harness
ignition - black/orange, ignition harness
If you trace those two 12-gauge wires back, they should lead you to the starter wire, which you'll need to reconnect.
The alarms back then were factory add-ons from a 3rd party.
Once the starter wire has been connected, just remove the harnesses from the brain. The orange wire to the relay is used as a trigger to enable the starter kill. The yellow wire should've been connected to a 12V source, IIRC.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
