4 speakers, 2 subs on amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2004, 04:41 PM   #1 (permalink)
View JohnCWms27's Photo Gallery
I'm planning on getting a 4Channel amp - whats the best way to hook up my 4 speakers and my subs? right now my subs are running parallel into a mono amp, and I assume I should keep that setup using 1 channel on the new amp. With the speakers, can I bridge two speakers into one channel, and then bridge the back two speakers into another channel?
'94 Camry LE
JohnCWms27 is offline   Reply With Quote
Old 09-14-2004, 05:02 PM   #2 (permalink)
cam2Xrunner's Avatar
Use the 4 channel amp for just the speakers. You won't have enough power to run 4 speakers and 2 subs off a 4 channel amp.
Old 09-15-2004, 08:11 AM   #3 (permalink)
whats the best way to run the second amp...just run in completely separately from the 4channel amp?
'94 Camry LE
Old 09-15-2004, 01:27 PM   #4 (permalink)
Get a d class mono amp for the subs. Use 4 gauge from the battery to the amps and use a distribution block to seperate the power lines to each amp. If you're not running a bunch of power use 4 gauge then after the distribution block you can use 8 guage to each amp. Have the two 8 guage ground wires from the amp connect into a distribution ground block. www.knukonceptz.com is a good place to get all your installation stuff.
Old 09-15-2004, 01:34 PM   #5 (permalink)
toyo man for life
View 97avalonxls's Photo Gallery
i dunno if you did your subs yourself, but you need to make sure tat you have an inline fuse especially if you're going to add an amp. BTW I would definately not run the subs off a 4 channel, they are usually A/b amps and you would do much better with a D mono. what kind of amp do you have now? subs?
Peace cannot be kept by force, it can only be achieved through understaning. - Al Einstein
97avalonxls is offline   Reply With Quote
Old 09-15-2004, 02:20 PM   #6 (permalink)
No i didnt do the subs myself, but i recently re-did the wiring...it does have an inline fuse by the battery. Speaking of which, isnt that fuse supposed to be the same as the fuse in the amp? Cuz my amp has a 30a fuse in it, and my inline fuse is 80a (originally 50a)
Anyways back to the subject - its a Xplod 480 Watt amp with 2 10" Xplod subs. (i know it sucks but thats why im upgrading).
'94 Camry LE
Old 09-15-2004, 03:08 PM   #7 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
I prefer AB on subs, how much power do you want to run should be your first question.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 09-15-2004, 03:13 PM   #8 (permalink)
I'm familiar with A, B, and Class D amps but what exactly defines them as such - is it the wattage or just how the manufacturer decides to label it? (obviously Class D amps have most power, but is there a cut-off line for which class it falls under?)
I'm not sure how much power I want to run on the subs yet, because that also depends on which subs I get as replacements. For my speakers I'd like to send about 100W RMS per channel if I could
'94 Camry LE
Old 09-15-2004, 06:28 PM   #9 (permalink)
Got SQ?
eddiem67's Avatar
Just make sure the rms rating (not peak) can handle that kind of power.
Class D do not have the most power, they are just a little more effiecent amp than a class ab.
so you know power on the front what about the sub, 250,500,1K?
Gen 4 V6
Old 09-15-2004, 10:03 PM   #10 (permalink)
the amp i have now is 480W Peak - about 150-200 RMS
'94 Camry LE
