2004 Celica GT Factory Radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2004, 09:55 AM   #1 (permalink)
View ejfont's Photo Gallery
We have a 2004 GT and we are having serious problems with the factory radio. It will not tune into local stations or any other stations using the scan/seek function and even when you tune to the station, it is still very bad reception.
Anyone else have this problem?
ejfont is offline   Reply With Quote
Old 09-23-2004, 12:13 PM   #2 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
A couple answers to this simple question..
1) Is the antenna extended?
2) If it's a power antenna, is it extended when the radio is turned on?
3) Is the antenna cable connected to the rear of the headunit via the antenna slot?
4) If it's a power antenna and it doesn't extend when the radio is activated, it may be a problem with your wiring harness. Try looking at the stock one and making sure the correct wire is connected and not ripped\shorted.
Hope this helps
troy is offline   Reply With Quote
