Compustar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2004, 11:38 AM   #1 (permalink)
View rirolarma's Photo Gallery
Compustar
I just got a new Compustar 2W900 alarm system with remote star installed on my 2005 Corolla XRS, this thing rock!... Amazing range, work well with manual.... I need to go back to the shop for some adjustement and install a electric trunk opener.
One question, the installer say it's not possible to control the sunroof as toyota use some kind of computer to control. Anybody had the sunroof controlled by alarm system?
Dan
rirolarma is offline   Reply With Quote
Old 09-22-2004, 11:41 AM   #2 (permalink)
Gameroom cash: $147537
As long as there is button to open/close the sunroof, you can control it. Usually ECU will cut power to all power windows after car is shut off. That's what I gonna do with my Celica.
Old 09-22-2004, 11:49 AM   #3 (permalink)
that's what i was believing also, but he said that it was on some databus.. anyway I think I'll take a look by myself to see how it's done
Dan
Old 09-22-2004, 11:55 AM   #4 (permalink)
Yea, just connect the relay to the switch instead of the brain. That's how I did my power lock to alarm, direct to the switch wire.
Old 09-22-2004, 08:59 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I'm not sure about a sunroof.
But for power windows you need a seperate module (window roll up/down module).
"Skoolin' the unlearned!"
Old 09-23-2004, 09:47 AM   #6 (permalink)
Yes, the module set how long the open/close switch will be activated. Alarm usually only output a short pulse which is good for door lock/unlock. You'll need to hold the window switch for a few second to get it open/close.
The compustar can hold the pulse to 2 sec. If you use one button to open, one to close, you don't need a module. Same to window. You'll need the module if you want to open and close with one button.
