'92 Camry: bigger than 4" speakers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2004, 02:45 PM   #1 (permalink)
View Stooker's Photo Gallery
I have a '92 Camry with roll-down windows, and the speaker locations are for 4" drivers. The speaker mounts in a plastic piece that raises it so that it doesn't hit the window. The opening the plastic piece screws into is oddly shaped. Other Camrys from the same time (that had power windows) had 6.5" speakers, also in a plastic bracket. My question is, if I get the plastic piece from a higher trim level Camry will it screw into my door and can I use it to put bigger speakers in? Or am I stuck with 4"?
Thanks,
~Eric
(I also posted this in the Camry forum, apologies if that is bad form)
Stooker is offline   Reply With Quote
Old 09-24-2004, 07:34 AM   #2 (permalink)
View Fever's Photo Gallery
Well you might try getting those other plastic brackets for a 6.5 from a junkyard, it might work I don't know for sure.
You could also make your own mdf brackets and use the same mounting holes, then screw your speaks into the mdf bracket.
Kinda like what I did for my '97Camry.
And do some measureing then check the depth of the speaks you might like to get.
'97 Camry XLE
Fever is offline   Reply With Quote
Old 09-25-2004, 11:35 AM   #3 (permalink)
View dave_thomas's Photo Gallery
Where did you put your tweeters at? From the pic it looks like you have them in the sail panels or whatever they're called.
dave_thomas is offline   Reply With Quote
Old 09-25-2004, 01:14 PM   #4 (permalink)
^Yes, in the sail panel. That's where the stock ones were and I changed them out in that instal.
The latest instal has tweets in the kick panels and in the A-pilars.
'97 Camry XLE
Old 09-25-2004, 07:03 PM   #5 (permalink)
I never knew they had stock tweeters in the sail panels. I knew they had them in the upper part of the armrest though. I custom mounted mine in the sail panels and they look alright, just need some finishing touches or something to make it look good.
Old 09-27-2004, 05:34 PM   #6 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
you should definitely finish off deadening that door.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
