A friend of mine wants to get new audio equipment - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2004, 02:32 PM   #16 (permalink)
View .tony. .riot.'s Photo Gallery
Originally posted by eddiem67
Nothing wrong with Xtant amps, tony if your friend wants more sub for his money, I have a pair of rockford fosgate 10" with enclosure for 100 bucks.
I'll talk to him and let you know.
Also, for two 10" Special Edition Audiobahn subs (double coil, 300 watts), which amp or how many watts would you recommend?
.tony. .riot. is offline   Reply With Quote
Old 10-08-2004, 02:52 PM   #17 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
I am not an audiobahn fan, so I dont know, you can ask finese1
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 10-08-2004, 04:12 PM   #18 (permalink)
View finese1's Photo Gallery
To be honest I'm not event familiar with those what's the model number. Like any sub just try to run it to the rms. Wire it so it can handle the proper resistance. An amp with the correct power will be fine.
finese1 is offline   Reply With Quote
Old 10-08-2004, 10:49 PM   #19 (permalink)
When I get back home I'll let you know what model they are.
Old 10-11-2004, 10:42 AM   #20 (permalink)
So, if they're 300 watts RMS, a 700 watt amp will be good?
Old 10-11-2004, 07:45 PM   #21 (permalink)
Are you running a 2 ch amp at 1x700 watts rms. If you are then run the 2ch one for each sub at about 350watts then it's fine. But you plan to buy a mono block or bridge a 2 ch. amp at 700rms then you are gonna damage the sub.
Are you gonna bridge the subs are run them seperate. Oh yeah those subs are for sure a 4 ohm or 6 ohm sub.
Old 10-12-2004, 11:45 PM   #22 (permalink)
It's an AW1051SE, Special Edition Daniel Jones Signature Series Subwoofer.
Here are the specs:
45 oz. Strontium Magnet
Power Handling: 300watts R.M.S.
Frequency Response: 28Hz - 1kHz
Efficiency: 91 dB
PHAT: Foam Surround
Non Pressed, Non-Transfer Paper Cone
KM3' Coated for Virtually no Cone Distortion
2" 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Mounting Dimension: Depth; 4 5/8"
Hole: 9" Diameter; 10-1/4"
Mult-Connect Lug Lock Terminals
Let me know some amps that you would recommend.
Thanks.
Old 10-14-2004, 09:49 AM   #23 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
MTX Subs and amps are pretty nice, phoenix makes good amps too
WhiteRabbit is offline   Reply With Quote
