Alternator - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2004, 02:55 AM   #16 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally posted by downsouthdx
ok so I need a new battery... how much do these optima batteries cost?
They start at about $120.
also I may sound stupid here but what do you mean by upgrade my big 3?
http://forum.sounddomain.com/forum/u...c;f=5;t=007801
"Skoolin' the unlearned!"
Old 10-06-2004, 08:11 AM   #17 (permalink)
View downsouthdx's Photo Gallery
thanks alot for the info dude
90' Toyota Camry JDM 3sfe Automatic
downsouthdx is offline   Reply With Quote
Old 10-11-2004, 06:36 PM   #18 (permalink)
New Alternator
Well...I checked at an audio shop in town last weekend and the guy there referred Dominic Iraggi also. So I called him up and he said he will sell me a 180 amp alternator for $379. He said it is direct bolt on and I could have it in barely over a week I think is what he said. What do you guys think?
Old 10-11-2004, 07:53 PM   #19 (permalink)
N/A bites
Tercel GTS's Avatar
I'd find out if that 130a unit from an 01+ highlander will fit first.
You can get them off car-part.com for 75 and up.
A factory rated 130a will actually put out around the 180, they are very conservative on their ratings
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 10-12-2004, 05:41 AM   #20 (permalink)
Repatriated POW
View supraturbo's Photo Gallery
Bud, your alternator is 14 years old.
Get a rebuilt one, unless youre running some serious SPL setup.
And yes, a spiral coil battery would help as well. Not only is the battery able to charge and discharge frequently, but it takes a FRACTION of the time to charge one than a standard battery.
If it charges in less time, you're less likely to kill it.
(¯`·._.·[ s£ïm ]·._.·´¯)
-87 Supra Targa Turbo-
supraturbo is offline   Reply With Quote
Old 10-12-2004, 10:12 AM   #21 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
I have a drop replacement iraggi alt, works great, but I needed it to run my 2100 watt system.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 10-12-2004, 11:20 AM   #22 (permalink)
well...what i think ive decided to do...partially by influence of money...is go to pepboys and get abt a 90a alt., optima yellowtop battery and also do the 'big 3' upgrade ppl have been talking about. if any more problems exist ill just get a capacitator....itll be cheaper than the HO alt and its gonna be awhile before i actually get to put my plans for my sound system into action so this will work for the time being....
Old 10-12-2004, 01:00 PM   #23 (permalink)
Got SQ?
eddiem67's Avatar
A cap will will actually draw more current, once its used up the stored voltage, usually takes about 10 seconds to drain it.
Gen 4 V6
Old 10-12-2004, 01:04 PM   #24 (permalink)
View oibone781's Photo Gallery
I have a voltmeter on my battery and it sometimes reads 14.4v with my car started, does this mean i have a bad alt. Also how do you disconnect the positive wire on the battery where is it connected, i want to change it to 4 guage wire..thanks...
oibone781 is offline   Reply With Quote
Old 10-12-2004, 02:49 PM   #25 (permalink)
Got SQ?
eddiem67's Avatar
14.4 is perfect, check your voltage at your amp if it still reads 14.4 or even 13.8 dont change a thing.
Gen 4 V6
Old 10-12-2004, 08:19 PM   #26 (permalink)
Ive been checking it all today, and it hasn't run a 14.4 again, i think the battery was cold or something. But anyway, i added a 150 anl fuse holder to the + on the alt to the +on the battery, and it still cuts off, next thing i will do is add a battery, i will maybe do this tommorow, if that doesn't work, i will change the ground wires, then if that doesn't work, i'll give up on my sound system, how do you disconnect the positive wire going to the battery...
Old 10-13-2004, 09:25 AM   #27 (permalink)
Got SQ?
eddiem67's Avatar
oibone, are you having electrical issues? what is the problem, start a new thread and explain your situation.
Gen 4 V6
