I don't know if you can replace the light, but to get the radio out you need to pop off the plastic part that runs around the radio and cassette player. It also holds the cigarette lighter. I just used a knife or a flat head screwdriver and gave a gentle pry along the outside passenger edge to get it to pop out, and was able to pop the rest of the peice off. I don't remember, but you may need to disconnect the cigarette lighter to remove it completely. I hope this helps, good luck.
Josh
Lucky Guess
96 Camry Coupe 5-speed 5s-fe
