97 or 98 Camry Radio Install Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2004, 01:43 PM   #1 (permalink)
View azn1028's Photo Gallery
i am installing a CD player in my girlfriends 97 or 98 camry V6 LE. i bought this shitty connector that says it works for camry from walmart, but it didnt fit. is the 97-98 camrys like certain hondas (like 98+ accords) where this is a special adaptor??
also, i noticed the back of her factory head unit has 2 plugs, but the new headunit has 1. is this kinda like the maximas where u need an antenna adaptor too??
thanks
allen
azn1028 is offline   Reply With Quote
Old 10-11-2004, 04:00 PM   #2 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
You will need both harnesses if your wire up the radio only, if your adding amps, then you only need 1 harness.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 10-11-2004, 05:23 PM   #3 (permalink)
im not adding amps.. you mean i need a normal wiring harness and that dumb antenna adaptor too?? is there a specific one for camry or is it a generic toyota one, cuz the generic toyota one that says it fits camry from walmart.. didnt..
Old 10-11-2004, 06:00 PM   #4 (permalink)
Got SQ?
eddiem67's Avatar
no the antenna should plug right into your deck, there should be two harness for the speakers and power.
Gen 4 V6
Old 10-11-2004, 06:51 PM   #5 (permalink)
Luc
View Luc's Photo Gallery
Re: 97 or 98 Camry Radio Install Help
The unit will NOT work with her existing wiring since she doesn't have an OEM amp behind the glove box. The unit is only a preamp deck and will need an OEM amp with all the OEM wiring bundles. Get another unit is your only other affordable option.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 10-12-2004, 11:34 AM   #6 (permalink)
just to clarify.. facotry deck has one connector for the whole head unit. it has 2 connectors for the antenna. i tried to purchase something similar for maximas that puts the two antennas into one antenna that will plug into an aftermarket head unit. will that work?? also, yes, none of the wiring harnesses for 97/98 camry's seem to fit the plug from her factory wiring.
so what are my options?
Old 10-12-2004, 07:39 PM   #7 (permalink)
Luc
You do NOT need to get an antenna adapter for converting the regular and diversity antennae into one. In fact, it does NOT exist. Just use the main one and leave the mini-plug unattached. Again, your options are to get another OEM unit which mates with the 2-plug, or get an aftermarket. Do you understand now?
Old 12-31-2004, 04:10 PM   #8 (permalink)
View gouki64's Photo Gallery
Hey Luc, I just installed an aftermarket deck into my avalon. There were two antenna plugs, the regular one (big plug) and a diversity one (small plug). Whats the purpuse of the small one?
gouki64 is offline   Reply With Quote
