capacitor always on? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2004, 09:22 AM   #16 (permalink)
View david in germany's Photo Gallery
Originally posted by Pineapple
Mine turn off within 30 sec. It turn on when there is >0.1V change in system. Don't know if opening the door, unlock with alarm will cause it to turn on. So maybe leave the trunk open for a few min to see if it turn off.
I'll be tough to get a big enough relay to switch it off with ignition.
Depends on the brand....
All of my Harrison labs stay on all the time. One shows good voltage and the other shows fully charged. if it has power from the battery then thay should be on (fully charged) unless you have a High current relay that disconnects the power when the car is turned off ( I have never seen a relay that big though)
so depending on the type of cap it is prefectly normal and you should only worry if it goes out...
David
I am in my own little world but it's ok they know me here!
david in germany is offline   Reply With Quote
