amp deck blows out fuse.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2004, 09:58 PM   #1 (permalink)
View spongebob's Photo Gallery
Question amp deck blows out fuse..
when i took my deck out couple weeks ago to put the stock radio to make the antana to go back up then i put the aftermarket deck back in and it blows the fuse, the fuse is a 15 amp blue fuse that lights up the parking lights when driving at night. every time i put the deck in it blows the fuse i put the stock radio back in and fuse does not blow does any one knoe whats wrong do i need or new deck or what. thanks
spongebob is offline   Reply With Quote
Old 10-28-2004, 11:59 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Check the illumination wire on the deck.
If its grounding with anything, it'll blow a fuse.
"Skoolin' the unlearned!"
Old 10-28-2004, 12:54 PM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
re-check your wiring, obviously something is not wired correct.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 10-28-2004, 05:58 PM   #4 (permalink)
so i need to do is right now is to take off all wire on the harness and the harness to the deck, and rewire them? i took off all amp wires like the red and gound and the blue wire from deck to amp.
Old 10-29-2004, 10:53 AM   #5 (permalink)
Got SQ?
eddiem67's Avatar
Thats a problem, the only wire that need to go the amp is the remote turn on wire (blue).
Gen 4 V6
Old 10-29-2004, 01:21 PM   #6 (permalink)
View finese1's Photo Gallery
[Bi took off all amp wires like the red and gound and the blue wire from deck to amp. [/B]
Your power wire (red) should be coming from the battery. Your black (ground) should be coming of the amp onto your chassis.
finese1 is offline   Reply With Quote
Old 10-29-2004, 06:02 PM   #7 (permalink)
yeah thats correct but every time i put on the deck it blow fuses im going to check the illumination wire is that the orange wire? do i need to tape that off?
Old 10-29-2004, 08:06 PM   #8 (permalink)
The HU have a illumination feature. If not you should hook the dimmer up.
Old 10-29-2004, 08:09 PM   #9 (permalink)
If not you should hook the dimmer up.?? what do you mean?
Old 10-29-2004, 11:34 PM   #10 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
TAPE OFF EVERY WIRE NEVER LEAVE AN EXPOSED WIRE
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 10-31-2004, 11:16 AM   #11 (permalink)
I'm sorry didn't explain correctly or type rather. I meant to say if your HU does not have an illumination feature which can be adjusted to dim according to the car dimming fuctions the dimmer should NOT be hooked to the HU.
