the plastic bezzle piece around the radio is held in with mostly clips, if you get on your knees on the passenger side and look up at the bezzle, you should see 2 screws holding in the piece, remove the ashtray and double check that there is no retaining screw there, i dont beleive so. Teh new Toyota clips are quite strong, but unfortunatly fragile, you are going to need to tug a little bit on the bezzle. But apply even pressure when pulling (both sides at the same time). Thats it nothing tooo mystical. I tried to get an exploded view for you, but unavailble at this time because im not at my store. Good luck
If it doesn't kill you, it only makes you faster!
